Results 1 to 9 of 9
Thread: 3 to 1 NP205 Gears
    3 to 1 NP205 Gears
    whats the point in that....guess you should have baught a jeep....my dana 300 has a 2.72:1 low gear....
    Steven W
    02 Dodge 2500
    Rex
    Ok, lets do the math here:
    Jeep CJ-5
    T-150 2.99:1 first gear x dana 300 2.72:1 = 8.13:1
    Chevy Blazer
    SM 465 6.5:1 first gear x np205 1.99:1 = 12.9:1!!
    There were no Jeeps that came with a granny gear transmission and a dana 300. The t-18's always had a dana 20 behind them which has a 2:1 low range!!!
    Club Old Man mark's Avatar
    Actually, both of those combinations suck in terms of low gearing.
    Just pointing out the obvious.
    BTW: My jeep was the king of poor stock gearing:
    3.82 (1st) * 2.61 (D300 low) * 2.72 (gears) = suck
    But its nothing a Klune won't fix.
    -Mark
    Krawler68
    Stock Early bronco gearing:
    3.03 (1st gear) x 2.67 (low range) x 3.50 (axle gears) = 28.035:1
    ouch
    Modified EB crawl ratio:
    6.69 (1st gear) x 2.67 (Low range) x 5.39 (axle gears) = 96.28... not that's a better start... nothing a Klune V can't fix
    As far as Krebs ratio goes... he has a 700r4 and it's a bad mofo in gearing... my E4OD isn't too shabby either...as autos go...
    I got ya beat mark, 3:1 (t150) 2:1 (dana 20) 3.55 stock gears
    21:1 crawl ratio.
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    What would that cost? $1400 with the doubler?
    Mar 2002
    College Station, TX
    New post a' la Nix style....
    SM 465 6.5:1
    NP205 1.99:1
    Axle Gears 4.10:1
    53 and some change:1 x KLUNE = A LOT:1
    ~dso
    Rex
    How bout my stock mog.
    14.9 first
    No t-case
    7.56 axle
    112.6:1 final
    Now add a crawler box that was a factory option with a 45.9 reduction.
    347:1!!
