Results 1 to 10 of 10
Thread: Cold Air Intake
    AgDieseler
    Cold Air Intake
    Finally got it done tonight.
    Enormous thanks to Flem and the Brunes, specifically Fred, for tons of help and a warm shop to work in while it snowed over Christmas. I owe you both a dinner and dark beer(s). St. John did the sweet ass TIG welding for the CDR fitting.
    Here's the before and after:
    Aug 2002
    nice work! what material did you use to seal against the hood?
    jwingfield2k
    i cant tell from looking at it. Is it an AFE? Im thiunking thats what i want, but im not sure.
    AgDieseler
    Thanks.
    It's the AFE that comes in the Dmax and CTD 600 kits. It's pretty damn big. 22 gauge makes up the walls, and garage door sealer from Lowe's provides the seal against the hood.
    The turbo is loud as hell now, as are engine rumbles. EGTs dropped a little, and the seat-o-the-pants dyno noticed a slight change.
    jwingfield2k
    did you just buy the element, or was it a kit? if so how much was it? i found one for a little under 300 im thinking about.
    AgDieseler
    Yeah, that should be the airbox and filter minus an intake tube. The element is all that I bought, and I found it on the internet for $65 + shipping.
    jwingfield2k
    ok cool thanks. I would think I would probably have to use my metal intake tube that is already there, (the one on my turbo)
    jwingfield2k
    well i was wasting time tonight on the internet and i ended up getting the afe cold air intake setup.
    http://www.shopdiesel.com/index.cfm/...oduct_id/4.htm
    and i got two bottles of fuel additive for mi truck too
    BigRedFord04
    Quote Originally Posted by jwingfield2k
    well i was wasting time tonight on the internet and i ended up spending too much on the afe cold air intake setup from some specialty diesel site that overcharges.
    EBAY!!!
    what do i care? its your $$
    jwingfield2k
    thanks austin, for some reason i just remembered that after i pressed Process Order. But I had to buy two other things from that one site so it barely evened out. I did buy some edger blades on ebay if that makes you happy.
