why the hell is my intake manifold leaking antifreeze around the bolts? They didn't look like water passages when the heads were off.
Might explain some smoke
Did you have to thread seal yours?
hmm....I don't remember them running into coolant passages, but It makes sense. Put some teflon sealant on them and see what happens. What's the oil look like?
i know i dont have a scout but on fords the threads go into the waterways. i had a problem with that. I put the blue gasket sealer on the threads and it fixed it. they also make some thread sealer i think. I know chevys can leak oil from the intake for this reason as well.
Think it was an optical illusion, leaky hoses. thread sealed them anyway and the smoking seems to have lowered.
Found a short in the harness and the ignition switch plug was kind of melted. I'm hoping that it added enough resistance to make the efi **** up.
This might delay the master plan
why wasnt i included the the "scout folk" category? not that know anything about IH engines though...
Originally Posted by agjohn02
345 crowd only, sorry
Now if/when the master plan happens, I might ask you about your previous engine
alls i know is it sucked and was
fuel injected chevy v8 is where its at.
I know of your master plan and I agree that it is . ...about as as putting a Rover V8 in that thing.
whatever, I do what a want
and as a side note, the guy who I bought my truck from's son's fiance is on Dr. Phil right now. She's the 280 pounder.
scout engines will run forever, that or until you find a 5.3 for 50 bucks...
Boats and hoes
in all honesty (5.3l vortec) i think "the master plan" will work well (5.3l vortec) but there something about (5.3l vortec) going from what you've got, a v8, to what (5.3l vortec) you plan to go to that (5.3l vortec) defies logic. if you decide to change (5.3l vortec) your mind and need (5.3l vortec) some advice on what engine (5.3l vortec) you should go with just let me know (5.3l vortec) and ill be happy to share my (5.3l vortec) opinion with you.
subtlety is your middle name, isn't it?
Jon "5.3l Vortec" Cox
actually thought about the rover engine for a brief second or 2, just need to get that range rover to 727 adapter plate
that engine is ****ing shot, pissed the last 3 days away on it, finally did a comp. test and its no better than it was before I swapped heads.
Time to start taking stuff off of it.
