Results 1 to 3 of 3
Thread: fuel cell
    Shaggy
    fuel cell
    i need a fuel cell for the bronco... what company should i get it from... what size should i get... i am gonna be getting really bad mileage and i mean really bad
    Nov 2002
    Tx
    RCI makes a good fuel cell. I've got an aluminum one in my FJ. Go by Eaker Performance, he has a lot of steel and aluminum RCI cells in stock and you can see what they look like and how they might fit in your truck. All the circle track guys use steel cells. They're pretty big, up to 21 gallon I think. You might need to put some foam baffles in there to keep the fuel slosh down though.
    BDR
    Shaggy
    i have noticed that people with wider/shorter cells often have problems at angles. as in the fuel is all in one side of the tank... has anyone seen a cell that doesnt have this problem... i guess the solution would be just to keep it full
