i might feel like lending a hand.
i prolly can.
39.5 iroks? or 36 iroks?
39.5s are bad doods come by and check em out... i got the radials... the bias are a lot cheaper
tate, ive seen em. and they are pretty sweet looking. i forgot you had them, i was thinking about codys 36s, but i think the 39.5s will be a ltitler better with the d60
i have 4 38.5 super swamper tsl/sx's for a 15 inch rim for $750. maybe 1000 miles on them.
i need atleast 16rim for my brakes. thanks though.
Hey quick question, I'm having alot of trouble with my acceleration. I replaced the throttle cable and no luck. It won't go unless I press the gas pedal really hard, and then it kinda "takes off". What else do yall think it could be?
well it depends. use your hand to work the throttle body. it could lie in the cable or the throttle body.
im guessing its the throttle body since ive alread replaced the cable then.
but if your cable isnt the right length then it could be that, move the throttle body lever with your hand with the engine running and see if it rev's up or not. that should answer your question.
I think the problem is the throttle body, it sticks a little bit when you push down the throttle
throttle blades aren't centered. loosen the torx bolts, open and close it a few times, then tighten.
best fix for that is to open them up while it's running and throw a washer, coin, or nut down in there...works everytime.
