1996 Suburban 3/4 ton w/ Vortec 454. Note:The 454's have Sequential EFI and not the central pod thingy on the Vortec 350's.
The symptoms: Every now and then when I try to crank the engine it doesn't want to fire. I have to give it throttle to get it to catch...which is no bueno in an EFI motor.
Also, when it does this as you start to drive it and you floor it it pings bad under load (not all the time). Has a miss a idle too. Not a steady one just every so often. My first guess is either ignition or fuel pump. Truck has 78,000 miles. All the wires, plugs, cap, and rotor have been replaced....so I'm thinking fuel? Maybe the pump is on its last leg? check valve is failing and the system has to reprime up to the engine?
The other thing I think is wrong is when it starts up it seems to really throttle up high at first. It revs to about 1800 RPM then settles down to a high idle (which I'm guessing is normal for when it's cold outside) of around a 1000 RPM until it warms up just a tad, w/in a few minutes-then drops to 750 RPM. I replaced the IAC, thinking this was the problem w/ the idle at start up and it didn't help any.
No check engine light....I'm figuring since there is no Check engine light that there wouldn't be any codes stored. Chevy fuel injection is a new one on me to what are typical problems. The Haynes manual sucks balls b/c they cover absolutely nothing when it comes to Vortec 454's...not even a pic in the book. The book pretty much reads: This is how you remove/fix problem "X" on a Vortec 350...If you have a Vortec 454 it's different and you're **** out of luck.
