I like grayson's explenation. I know that the lack ofa rear swaybar right now and having the front connected definetly helps in picking up the front tire. But it sure does make u turns interesting.
I know, i know, "cause its a jeep thing, and you wouldn't understand", but of course neither do they.
Longer links will return the geometry of the front suspension closer to factory. The longer links will have less of a nangle. Kind of like rigs with short rear links getting so much rear steer.Originally Posted by uglyota
I've spent several hours on the ****ter with just about every book Dallas public library has on the topic.... here's whats up
the longer flatter links is hillbilly talk for getting the angle set up right. You want the uppers and lowers to intersect at or above the plane parallel to the ground that the center of gravity is on or you get squat. Above the line the ass end jacks up. Lift a link suspension and the link angles go up and the 2 intersect higher above the center of gravity plane and the ass end jumps like a lifted TJ.
In none of these books was the phrase "vertical seperation" used. Thats a pirate 4x4 idiot term.
swaybar has nothing to do with locating the axle, it just increases the spring rate as the suspension compresses on one side of the vehicle while decreasing on the other side
[QUOTE=uglyota]how do you know where your center of gravity is?
in hillbilly terms please
QUOTE]
draw a solidworks model with correct mass properties and it'll tell you. oh, hillbilly terms... jack it up in the middle where it'll balance, thats the longitudinal location. for verticle upsprung Cg id say a guess is in order.
expensive scales, weigh it, then raise one end and weigh it again. see what the weight difference is on one end, then cackulate it using a bunch of trig and vector stuff. There was an easy plug in formula I read awhile ago, don't remember it but its probably google-able.
oops, i meant verticle sprung Cg. you can assume the unsprung Cg is neglegible since the axles, tires, and wheels weigh roughly the same and that weight wont affect how the body moves.
Look for the 4-link calculator on pirate...if you can't find it let me know and I'll hunt it up on my computer and send it to you.
ive got it too
take you shiznit to the scales at a place like a iron scrap yard...weight it on all fours. then you do several combos of lifting...i think its like lift one front tire about 2ft and weigh it...then the whole front end and do it and a couple more....then as robert said, there are some calculations involved to find your exact COG...its on pirate somewhere just not sure where. also its on a jeep site...ill see if i can find it.
Steven W
02 Dodge 2500
here is a site that will explain everything in good detail...i know its for jeeps but it will still work for your toyody
http://www.jeepaholics.com/tech/cog/
and here is a word writeup and a excel spreadsheet to do all the calulations...
excel spreadsheet
http://home.att.net/~email.id/COGROAss.xls
word doc
http://home.att.net/~email.id/COGROAdoc.doc
Steven W
02 Dodge 2500
