Registered
1978 bronco (project)
Im going to have to puss out on my bronco. its a 1978 bronco that needs a little work. There is no rust on this thing anywhere. the motor is not in it, but i have a 400 that just needs to be put together and put in. the heads and block have just been resurfaced, new pistons, crank, timing chain, all that good stuff. also have a set of 4" coil springs for the front. and a sky manufacturing shackle flip brackets. pictures here....http://tamor.org/forums/showthread.php?t=4664
make reasonable offer for whole or parts.
4 35 12.50 r15 xterrains with 5k street driven miles. mounted on black rock crawler rims 5 on 5.5. tons of tread left. 650
Registered
i guess be a puss with no debt and ride with people
Registered
ttt still have tires and coils
Regsitered Uesr
You find me a front 44 for $100, and I'll lift my yotoy high enough this summer to buy those tires from you.
- You may not post replies
- You may not edit your posts
Forum Rules
