Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: Bronco Dana 44
    Bronco Dana 44
    Complete Hi-Pinion Dana 44. Needs lockouts. even come w/ a panhard rod. Not positive on the ratio. I took a pic of the id tag on the pumkin.
    $250.00 May be even able to deliver or send via Brune Carrier Service.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    its a track bar.
    Registered User
    May 2003
    Htown
    where'd you pull that at? If you got it at the $30 axle place, I wonder if its the same bronco me and jimmy saw up there over the summer. I doubt it though.
    Oh yeah, those of you with ttb f-150's/broncos should buy this axle!
    So you loose, I win!
    Mud King
    on that axle can you cut the coil wedgy thingys off and tube under them?
    Quote Originally Posted by stx4wheeler
    its a track bar.
    redneck term? oh..wait I'm talking to Kevin actually for you it would be:
    axlelocatertokeepitfrommovingfromsidetoside.
    Is that better deuche bag, aka "hooked on phonix's bread and butter"?
    Quote Originally Posted by Mud King
    I guess you could weld perches on it. Just use some high nickel rod and pre and post heat.
    I could get a set of radius arms for it if antbody needs them.
    Jerry: not from there. that one is long gone and it was not at the $30 dollar place and they wanted like $275.00.
    fbronco86
    its a 3.50 ratio, open diff
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    yeah you can grind of the wedges, they are cast in there but you can get them off with quite a bit of grinding, search on pirate in the ford section there are some people with eb's, and bronco 2's. that have done it.
    oh and i think i got a set of lockouts for it if anybody buys it.
    Aug 2002
    isn't this is how Austin SASed his truck? Went really quickly...basically just bolted into the radius arms in place of the TTB?
    Registered william_ace's Avatar
    Feb 2004
    College Station, TX
    little more involved than that but, pretty much yes.
    actually...it was a lot more involved then that and here are the pictures of it...
    http://www.texasoffroad.net/galleries/lonestar/album83
    Steven W
    02 Dodge 2500
    usmcagg02
    thats full width right? how hard is it to convert to 6 lug?
    Feb 2004
    College Station, TX
    sent PM
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Quote Originally Posted by usmcagg02
    search pirate and you should be able to find your answer, but i imagine it wouldnt be extremely hard by swaping from the knuckles out with chevy outers, but would be much easier to swap to eight lug outers and a one ton rear or to take a nine inch to make it match the front would be the cheapest route.
  15. #15
    Yes, it is full width. It came out of a late 70's fugly bronco like the Frik's. I don't know how hard it would be to convert to six lugs. prpbably easier to carry two spares...one five lug the other six lug
