Page 9 of 9 FirstFirst ... 5 6 7 8 9
Results 121 to 132 of 132
Thread: Car Stereo Advice
  1. #121
    don't put that crap on your bronco
    It is incredibly annoying wheeling with you speaker pod folk when your stereos are on.
    the battery looking things are resistor capacitor circuits used to cancel certain frequencies. It limits the band that speaker will operate at.
  2. #122
    Brazos County
    The amp is crapola
  3. #123
    It's got a lifetime warranty
    F*ck off cj.
  4. #124
    PVC cap and parts store speakers......What I listen through while waiting for you fancy boat speaker bitches at the top of the trail
  5. #125
    Wasn't aware it was a race...........do those sound good when you're sitting on a cooler?
    F*ck off cj.
  6. #126
    Jan 2010
    do yours sound good in the box they came in?
  7. #127
    so I did a test hookup today.
    I hooked the rca's to the channel 1 and 2 parts and it wasn't right. sounded like they were little headphone speakers. Wtf are the hi level inputs?
    F*ck off cj.
  8. #128
    high level inputs should be line level inputs. Low level is what you want, make sure you have the gain turned up to the appropriate levels. Also where you using the Iphone?
  9. #129
    Chief
    Sep 2008
    make sure your high pass filter is set to 80ish hertz, that's probably why your **** sounds hollow. Also, match the gain to the output of the source unit (if it's 2v out, set it to 2v)
    high level inputs are usually used more for integrating OEM head units with aftermarket amps.
  10. #130
    I returned it. Didn't have high or low pass filters, ****ty in general
    F*ck off cj.
  11. #131
    Returned that **** amp, bought a used one for the same price. Has high and low pass filters, these speakers are the tits. Also, my 6x9's work, so bronca is gonna bump!
    F*ck off cj.
  12. #132
    I'm sure it will sound sweet sitting outside Evan's shop
