Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: 454, 350's, 6.2L's, 292, 2.8L, 14 bolts, 12 bolt, Th400's, SM465
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    454 out of 91 Chevy dually. Throttle body injected. Engine is 99% complete, everything included except aircleaner. It comes with the wiring harness and computer for a 4L80E, but no tranny is available. It ran with no smoke when it was removed. The truck it came out of had 96k on the odometer, but the engine has a remanufactured badge on the side of the block. It has serpentine accessories. $700 for everything, $500 for the long block only.
    350 core. Came out of 70’s GMC pickup in unknown condition. Truck did not run when I got it. Comes with accessories and brackets, no carb or distributor though. $200
    355 rotating assembly. Freshly rebuilt with 0 miles since rebuild, the rest of the engine hasn’t even been assembled on it. Rebuilt with a 4 bolt main block bored .030 over, federal mogul bearings, aluminum flat top pistons and a 300 hp comp cams cam all from a Scoggins Dickey kit. Have $1000 invested, will sell for $600.
    Three Chevy 6.2L diesel longblocks. All came out of CUCV’s and are in good shape internally, but are rusty as hell on the outside. Includes rotating assemblies and heads. $50 each
    292 Chevy straight six. Came out of a 80 Chevy crewcab. Did not run when it was removed but the PO told me the rotating assembly was recently rebuilt. Includes rotating assembly, head and intake and exhaust manifolds. $20
    2.8 L Chevy V6. Came out of 85 Chevy S10 blazer. Includes whatever you want off the vehicle, but no throttle body, the truck didn’t come with it. $50
    TH400 core. 4x4 NP205 long tailshaft version. Only reverse gear works. $20
    TH400. Perfectly working 2wd, came out of 84 Chevy 3/4 ton. $50
    SM465. Works perfectly. Came out of 80 2wd crewcab. Is complete except for shifter. $20
    14 bolt FF SRW with 3.73's and unknown diff. It is disassembled far enough to do disk brakes but 100% complete, even the drum brake parts if you want them. $100
    14 bolt FF cab and chassis dually (skinny version) with 4.10's and unknown diff. Great shape all over, truck it came out of only had 96k on it. It came out of a 91. Complete hub to hub and in 100% useable condition as is. $200
    12 bolt Chevy. Out of 2wd 70's GMC truck, 5 lug. Unknown condition, gears or diff. $50
    I can deliver stuff within Texas if I have enough interest. Pictures are available upon request.
    I'll take the sm465 and maybe one of the 6.2's. what do the bores look like? do they rotate? accesories included? injection pump? post pics of 6.2 please
    Rawr TexTJ209's Avatar
    Sep 2004
    Waco, Tx
    14 bolt is in the title but didn't see it listed underneath...if you do have one, what do you want for it and details?
    Nov 2002
    Tx
    I'll take the 4x4 turbo 400. Besides the fact that it's not working, is it all there?
    BDR
    Wylie, Tejas
    I want the 292 for my imaginary rat rod. In hot rod this month they have an article on how to get over 300 horse out of one. I think it would look kool. My imaginary rat rod is a few years out though, so I will pass...
    Boats and hoes
    Aug 2004
    Corpus Christi
    Old man; the 465 is yours, the 6.2 bores are good and shiny. They all rotate freely. All the accesories and injection pumps are gone. If you wanted to come down to kingsville you could pick out whichever one of the 3 you wanted, otherwise I can bring one up sometime. I'll post pics of the 6.2's as soon as I get my puter back.
    14 bolts...added, my bad.
    Bryan, the 400 is yours. Yes it is 100% complete, it came on the back of an engine I bought and the guy was too lazy to take it off. If you want I'll bring it with Grayson's stuff.
    Jimmy, if you havent already seen it, www.cliffordperformance.com is a very popular 292 hotrod parts source over on coloradok5.com. They make all kinds of crazy **** for 292's. You need it, just throw it in Kopeki's pile of crap until you need it, and hope he doesn't make a driveshaft out of it before then.
    I am trying to get enough stuff sold to make a large round trip through texas so I may be available to deliver other stuff if needed for a small fee. I have a 20 foot flatbed trailer so if you need a vehicle moved I may be the man to talk to. Jeff, I can bring your blazer up here from san antonio. $20 if it can drive on the trailer (gas money) and $50 if it doesnt (gas money and PITA to get it on and off trailer ).
    aggieblazer07
    i might take you up on that offer, but I'm a little further south than SA
    Nov 2002
    Tx
    Sounds good. Just bring it up to CS whenever you get a chance, there's no hurry (Lord knows I need more junk sitting around). Just let me know ahead of time so I can be up in CS too or make arrangements for someone to open the garage for you.
    BDR
    Aug 2004
    Corpus Christi
    Hey Jeff I forgot its in Dilly right? How far is that?
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    Looks like I'm late to the party. If Gaystroke doesn't take the 465, I'm interested if I can use it as a replacement for my current 4x4 model.
    Sep 2004
    About 75 miles south of SA. Basically a straight shot down 35.
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    Sep 2004
    Waco, Tx
    I'd like the 14 bolt with the 3.73s, but won't have any money till probably late June. So if you still have it around then I'll send ya a PM.
    aggieblazer07
    Cook is correct
    Violentv8toy
    how wide is that 14 with 4.10s?
    jeff, you're from dilley? im from carrizo.
  15. #15
    Aug 2004
    Corpus Christi
    The dually 14 bolt is like 63" wide I think. I'm not sure on the exact measurement but I think its about 6" narrower than a non-dually.
