Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: Relocating Axle
  1. #16
    Violentv8toy
    or you can get some hangers, cut the original crappy ones off and reposition and be done with it.
    or if you've grown partial to the crappy ones, cut the welds and grind down and relocate and reweld.
  2. #17
    Aug 2002
    crappy ones? Didn't you make them?
  3. #18
    TRDyota
    Yes he did. And yes, he knows they're crappy. I still have steel to make new ones, I just thought it would be a pain to get a torch in there. And the one side is mighty close to the gas tank too.
    Redrilling the spring perches still might be easier.
  4. #19
    TRDyota
    Okay, so I double checked the dimensions from Pirate, and I need to move the axle forwards .5-.75". Figured I would split the difference and call it 5/8".
    And, unless I just use a really really big drill bit, I think it would be easier to torch the holes in the spring plates.
  5. #20
    Dallas, TX
    Why does your axle need to come forward half an inch so bad?
  6. #21
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Quote Originally Posted by bburris
    exactly my thinking is half or 5/8 and inch gonna make a whole lot of difference. Why are you wanting to do this?
  7. #22
    Registered User
    May 2003
    Htown
    Quote Originally Posted by stx4wheeler
    ummm apparently you didnt read above PIRATE SAID SO!!!!! Next will be tauras fans, f150 springs, and what else was it jimmy?
    So you loose, I win!
  8. #23
    Wylie, Tejas
    I think Doug said it was an automated-plasma cutter...
    Boats and hoes
  9. #24
    TRDyota
    Because it bothers the crap outta me! It hurts me eyes big time. And if its a simple fix, and I am already in there to fix my shackles, then it I give it the green light. If its something thats more trouble than its worth, then no big deal. I think this one won't be too bad though. A simple redrill will give me mucho satisfaction.
  10. #25
    Dallas, TX
    Do you know how hard it will be to drill through multiple leaf springs with a hand drill? It was a pain to get through one with a drill press for an experiment I started and I still didn't trust it enough to run it...
  11. #26
    Aug 2002
    he's drilling the plate and perch, not the springs. It takes like a half hour. No big deal. Brandon I think it's a 1/2" bit, maybe 5/8" either way I have the right one.
  12. #27
    TRDyota
    Thanks, Eric. Its going to be a few weeks. I'll be giving you a call when the time gets closer, and we can figure something out.
