th350 2wd or 4wd, 700r, 4l60, or gm nv4500
needs to be in good working condition and cheap
uuuhhh...I thought you were going to take my 2wd th400?
If not.....I'll take it
BDR
i will if i have to... but i looked into it and they do not make an adapter for a 400 to a toyota case
but they do make them for all the others i listed....
if i cant find one ill take the 400 and just have a 2wd truck for awhile until i can find something else.
Well I have someone else that wanted it already so I need to know for sure whether or not you want it. If you are interested, I have a 2wd TH350 that may or may not work. $20 good day sir!
well if the 350 works ill take that... but i wanna make sure it works or at least check it out... if not ill take the 400
Like I said, no idea if the th350 works or not. The truck its in doesnt work so there's no way to tell. So you want the 400 for sure?
I know a guy that has a TH350 for sale. I also know that he has an NP205 that will fur shur bolt to it.
[darth vader]Coop.....come to the dark side. You want to run all chevy drivetrain. You don't want to run the yota tcase. I am your father...[/darth vader]
BDR
BDR how much for the TH350 and 205 or just the 350?????
if it is all working and stuff and not a **** load of $$ i will take it
if not
Robert i will take the th400 for sure
It's always worked great for me. I had a new input bushing and seal put in when I installed it, and I've changed the fluid and filter twice. It's got a small leak where the reverse light switch mounts in the housing, once it's out I'll see about getting a new oring. It also has a new TH350/NP205 adapter from boyce equip. I also replaced the orings in the intermediate shaft and the input seal on the tcase. I'd take $350 and throw in the shifter.
BDR
can you have it here by sat or sun????????????????
It's already up there. Just need to pull it out. You got time to help pull friday morning?
BDR
So coopy no need 400?
yeah ill help pull the th350 with you bdr sorry robert, its just cause i cant make it in a 4wd
but i do want you motor, ill talk to you about it some time this week again
thanks guys
what time and when BDR?
