One of my buddies just got a 76 blazer. What tcase-205 right? Main question: on the shifter it reads
High lock
High
Neutral
low
low lock
What does all that mean
Its a full time 4x4 with auto hubs
High lock
High
Neutral
low
low lock
Clayton Rollins '08
210-863-1435
2007 Dodge Ram 3500 4x4 5.9
1983 Waggy
It's the same as the ford. NP203. the loc selections are for locking the front to rear. Does it really have auto hubs or are they just a flat cap where the locking hub should be?
BDR
so im gathering that putting it in loc is the same as getting out and locking the hubs??? correct flat caps.
Clayton Rollins '08
210-863-1435
1983 Waggy
No, unless someone has previously installed a part time kit, the hubs are always engaged. There is always at least some power going to the front axle. Picture a locking differential in your axle, if it's open one wheel will spin easier than the other. If it's locked both wheels spin together. Now take that differential, and put it in the tcase between the front and rear axles. It uses the same principle, with the numbers that Jerry posted above.Originally Posted by texasxj
BDR
ok that makes some sense. I knew it had something to do with more power in certain gears.
Clayton Rollins '08
210-863-1435
1983 Waggy
203s are freaking heavy and the shifters suck on them. Does anyone know how to twin stick one?
Yep, put a 205 behind it. 203 is non-twin-stickable.
Not true. I believe ORD is working on or has already done a twin stick for a 203. I dont know what it accomplishes but on the 203 range box I got for free there are 2 shifting arms and they are at different positions. 203's are turds anyway, they are insanely heavy and excessively long. The only thing they are good for is using the chain housing for a tarp weight and the range box for a doubler.
speaking of 203s and 205s, does anyone have a 205 shifter.... charlie truck needs one
well if I can't twin stick it, I am going to need to find a new shifter too, or a 205 if anyone has a cheap one they want to get rid of
You're bustin my balls here Jeff.
http://www.offroaddesign.com/catalog...seshifters.htmNP203 twin stick shifters: $170
That's right, we can twin stick the 203! You get rid of the trouble prone and typically worn out factory shifter box and replace it with 2 levers for much more positive gear selection. One lever will shift the case through Hi-N-Lo and the other will control the differential lock, or on cases converted to part time, the other lever will control 2wd-4wd. This shifter can also be converted to a Doubler shifter with a simple linkage change. Available for GM, Ford and Dodge.
(970) 945-7777
for that price I might as well save up to get a doubler
i still need a ford 203 range box
