looks good! Make sure the aluminum's not too tight to those fuel lines, if they start to touch, the vibrations will rub holes in them (don't forget that your motor is soft mounted to the chassis)
yeah, I know. I still need to open them up some more. Same with the MC. I also need to get some form of insulating tape to put between the aluminum and the tubes to help with vibrations. Damn these fiansl, I should be out there working on it right now instead of studying.
BTW, I would have killed for a good dremel to use on this. I cut all the holes using a sawzall, grinder and drill.
****, I thought you didn't have one? Weren't we discussing this a few weeks ago? I still have some work to do on the hood, and I want to clean it up a little more, could I borrow it for a few days?
BTW, how do people do the brushed look? I want to do that to help hide some of the scratches and help keep the glare down
you can also do a "brushed finish" or Swirrled finishish using a grinder, or orbital sander, you just have to experiment on a piece of scrap
wire cup brush
Boats and hoes
im sure i could get my roommate to do the brushed flames on it, IMO that would look sweet
Ryan Clarke
(214)695-7901
explain more? Flames brushed into the metal, or painted on over it? Any one have pics of this?
brushed into it using a wire wheel, but the circle method is pretty easy using a wire cup like jimmy said
Ryan Clarke
(214)695-7901
now you have me wanting flames of some sort, whether they're brushed in or painted on
good, now i wont be the only idiot with flames once i paint the bronco
Ryan Clarke
(214)695-7901
flames are gay
I had some flames one time. Then I sprayed them with a water hose and they left.
