Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Question about 3"lift
    DRaf
    I had a question that i was trying to get answered ... I drive a 02 Wrangler and i have a 2"coil spacer, 1"motor mount lift, 1"body lift, and a 3/4" polymer front spacer and i was wondering if it's possible to take out the 2"coil spacer and replace my coil springs with ones for a 3"lift without any other components ... I already have the shocks so that is not a problem, i just don't know ligistically if this will work. Let me know porfavor.
    Sep 2004
    It should, but thats probably as tall as your going to get with stock stuff. Stock parts worked fine on my jeep until I went past 3"
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    Rawr TexTJ209's Avatar
    Sep 2004
    Waco, Tx
    Rear trackbar, and swaybar links might be an issue also..
    I think with my 3.5" RE, we also had to drill a new hole for the front trackbar, but that was a while ago..so I forget.
    DRaf
    yea swaybar is def gonna be a problem cause the stock one is not long enough ... but i'm not soo sure about the track bar, i think stock one might be ok
    Aug 2005
    Houston or a drag strip
    I say go with a R.E. 3.5" or 5.5" kit, you'll be thankful later that you didn't waste money on something that your just gonna want to upgrade later. Go with 5.5" and run 35"s like Brandon said, then when you get money, regear and lock it up. Just my .02.
    1974 CJ5-The BarnBurner
    Sep 2004
    Waco, Tx
    I'd definitely go with the RE 3.5", comes with everything ya need and isn't a tough install. You can run 33s fine with that combo. But, depending on what rearend ya got, you could keep the body lift, and shove some 35s under there. Regearing, locking-up, or spending any money at all on a Dana 35c (besides spare parts), is not a good idea.
    Aug 2005
    Just ask Creighton about his d35, unless you want to waste money on chromolly shafts, CTM u-joints, and a crap load of other stuff, it'd be better to just swap in something else. There's all kinds of options, but really unless your planning on making your rig a hardcore trail only rig I wouldn't worry about it. Just lock it up and be easy on the skinny petal (opposite of Creighton, just don't watch him.. ).
    Sep 2004
    Waco, Tx
    Creighton doesn't have a D35c, he runs a D30/D44. D35c is the standard rear-end in TJs, and is a horrible piece of crap.
    Aug 2005
    Ah, my bad, I'm being a tard.
    Sep 2004
    Waco, Tx
    Its cool, you don't own a TJ, so you havent come to know the POS known as the D35c.
    Tilloda
    or the POS known as the TJ
    Sep 2004
    Waco, Tx
    Least my **** has shocks, and doesn't sound like a lawnmower
    Aug 2002
    oh no you didn't just go there...
    luckily not all vehicles require shocks to keep their suspension intact
    Shaggy
    ha
  15. #15
    Sep 2004
    Waco, Tx
    Haha, good point.
    I still can beat you in a race.
