Axle Wrap and Torque Steer
ok...so...i know i get really bad axle wrap but after wheeling this weekend it got even worse and the driveshaft flanges actually hit the yoke on occasion. I think it might have something to do w/ the cracked lift block b.c. its missing a good size piece off the front of it. also, when i got it all back together the U-bolts arent at the same angle anymore but it looks like the plates the blocks sit on are level w/ the blocks. could i have twisted my housing? anyone know how to check this?
Also, I get really bad torque steer now, i think its even worse than before this weekend. opinions on what can cause this and how to fix it? thx all
When you redo your steering just build a traction bar for the rear...as for torque steer I imagine a lot of it is your steering angles and lack of a stabilizer with 37's... I think hydro assist should be in your very near future...
- You may not post replies
- You may not edit your posts
Forum Rules
