My little brother wore the pads down to the rotors, metal on metal, on his 99 Tahoe. I bought new rotors and warrantied the pads. I am trying to compress the piston with my c-clamp, but it is not budging. This is on the side that was bad. The other side went fine. The piston is sticking pretty far out. I beat on it with a hammer a little bit to see if it was jsut stuck, but no such luck. Is it frozen up and in need of replacing?
Brake fluid for the front was also very low.
Need help quick. Thanks
