nice. Thats the housing I need. Looks like he sleeved the stock 60 tubing rather turn and press new tubing in the knuckles. Not how I'd do it, but I wouldn't paint it red either.
wonder why he didnt just use a cut-off tool?
What's so less-common and weaker about a Ford 9?Originally Posted by uglyota
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
The 9" center can be built alot stronger than the D60 and have MUCH more ground clearence. 9" centers and housings are very easy to find. I would say they are a whole lot easier than finding a D60 center.
Scott, FTAC '99
edit: if there's a class or something that you need to run leaf springs in, that makes sense. Otherwise I think if you have the skills to build a hybrid axle, then you probably have the skills to link your front suspension
a center other then an EB one can be used...its just the one that flem prefers.
Steven W
02 Dodge 2500
they're talking about the old dtyle, non-webbed, small pumpkin 9"
says the man with the toyotaOriginally Posted by uglyota
I've got my reasons why I want to keep it this way. It goes against the opinion of the majority that says full width is a good thing, but its how I want it.
anyone with a single wheel gm 60 sitting around want to measure the center of the kingpin cap to the mounting surface for me?
I think Brett has one.
I have a Dodge and a Ford...
Scott, FTAC '99
you still want that 9inch from the other EB?
no, found one off an f150. de-tubed it already
If I was close to it I would, but it's across the state right now...
