So I had planned on buying H2 rims for the buggy and getting some kinda tire in the 17" variety. However, my 16.5" rims are beat to hell anyways, and one looses air because the edge of the bead is beat up.
So, I think I "found" a big enough piece of aluminum up at work to cut 4 17" rings out. For the outer ring I'm going to use regular steel so they'll hold up better. Another reason is that steel should be "found" also.
Most people don't mess with 16.5's because they don't have a safety lock. I've read a couple threads where people weld a bead around the circumference of the rim where a noral safety lock would be. I drew a line where I'd roughly weld a bead. Anyone see drawbacks to this?
