so what sound does a auto make when the torque converter is going out or you have something ****ed up with it... like if i slow doing coming to a stop at the last second you your a loud pop/click and same thing if im about to stop and still rolling like speeding up a little and back down i can make it pop back and forth. and now that i put the shifter in i ahve a small hole in the floor until i fid a boot for it, and i hear it when im driving now too.
and if i put the trans in nutral and just wiggle the rear drive shaft back and forth you can hear the same popping. and you can feel it when you put you hand on the trans.
torque converter? cluch packs? shift linkages? tail shaft bearing?
