Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Thread: jeep d30 hubs
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    jeep d30 hubs
    everything is put back together right. the locker is functioning correctly. however, the hubs are popping loudly and jerking the steering back and forth, like they are engaging and disengaging. they are warn aftermarket ones about two years old. everything inside looks good. any ideas?
    Shaggy
    are the splines on the stubshafts still good
    Apr 2004
    Cowtown
    look good to me
    Hazaa Fredo's Avatar
    Mine do that sometimes and I have no clue why. But it only does it once or twice, and it's usually right after I've put it back together.
    Apr 2004
    Cowtown
    this is about once every four seconds and only does it when driving. crawling around on a rockpile i didnt notice it at all.
    Oct 2002
    Poth, Tx
    How you sure its the hubs and not locker?
    Shaggy
    my locker used to do something of the like
    Apr 2004
    Cowtown
    yeah, best i can guess the hubs are pushing the spring loaded plunger out and letting the splines skip. i dont know any other way to solve it except get new hubs. maybe they wont do it?
    Apr 2004
    Cowtown
    ok, its not the hubs. its the ez-locker. does anybody know what the tolerance is on the gap in the middle. i put the stock thrust washer/shims back in there but it needs either more shim or less. i dont know which.
    Apr 2004
    Cowtown
    btt. anybody?
    Registered User
    May 2003
    Htown
    did you already check this?
    http://www.detroitlocker.com/images/DL-NS-install.pdf
    I just glanced over it and didnt see any specific things related to your problem, but a closer look may reveal something.
    So you loose, I win!
    Apr 2004
    Cowtown
    thanks, but thats the no-spin, like what goes in a 14 bolt.
    i need the ez locker stuff. im looking for thrust washer tolerances and center gap tolerances.
    by center gap, i mean the gap in the center
    Aug 2002
    the thrust washer clearances should be to factory spec I think, gap in the center I would think it's only important that it's able to smash together tight enough to unlock. Maybe take it apart and see if you have a broken pin? This is to be taken with a lot of salt, I couldn't even install mine without getting scott on the phone...
    Apr 2004
    Cowtown
    i pulled the cover, the pins are fine. the teeth are actually popping violently and slipping.
  15. #15
    Wylie, Tejas
    if the gap is not that wide just fill it in with some mig wire. If you can find Jordan I bet he could tig weld it!!
    Boats and hoes
