Results 1 to 13 of 13
Thread: lug nut tech?
    Aug 2002
    lug nut tech?
    My new alloy wheels have the lug nut seats kind of countersunk into the wheel, so that when it comes time to torque them only about half of the nut is sticking out of the wheel where I can get a socket on it. So I guess I need longer lug nuts, but I can't seem to find what I'm looking for. Is there a name for this style of lug nut? Where can I get them? Threads are 12Mx1.5
    Thanks in advance
    Wylie, Tejas
    blingin' chrome capped ones are probably what they are designed for. I know they make longer open style ones, where have you tried so far? Maybe Cooks can make you some
    Boats and hoes
    Aug 2002
    just looking on ebay, summit and jegs. Was gonna hit up oreilly this afternoon
    on the "shank" style the shank actually goes beyond the seat, right? I don't think i want that. Brandon and his friend Eric said that alloys need a style with washers?
    Wylie, Tejas
    I don't know what shank style means, washers aren't necessarily required, however it is more important to torque them down correctly.
    Boats and hoes
    VW Ninja Jackasic's Avatar
    Jackasicstan
    they have them up at Dixie Tire also.
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    shank style. the sleeve goes between the lug and the hole. the hole in the wheel is not tapered. i think they require a washer on aluminum wheels.
    aluminum wheels with tapered holes require a bigger lug nut than a steel wheel. if you use steel wheel lugs on an alluminum wheel the nuts will pull through the wheel leaving a nice hexagonal hole.
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    So you gonna post pics of the bling or what?
    Teaching America's youth RCcola55's Avatar
    Sep 2004
    with your mom
    whats with the staggered look u got going on right now
    Ryan Clarke
    (214)695-7901
    Registered User
    May 2003
    Htown
    yes the shanks make it a b!tch to put the tires on cause you have to lift up to the get lugs on. Its even more fun when the previous owner put gorilla locks on every lug
    So you loose, I win!
    Aug 2002
    Quote Originally Posted by RCcola55
    you mean my Texas Tilt?
    when in Rome...
    so on the shank style is the seat at the bottom of the shank or is it at the bottom of the "hex" (for lack of a better word)?
    I had the impression that the "shank" was going all the way through the wheel, but now I'm thinking that the shank only goes from the seat to the "face" of the wheel?
    Apr 2004
    Cowtown
    when in Rome...
    it makes contact at the bottom of the "hex". if it made contact at the "bottom of the shank" against the hub first, it wouldnt clamp the wheel on. the friction between the wheel and hub is what carries torque. not the lugs themselves, there should be space between the bottom of the shank and the face of the hub, if not, dont drive it.
    Nov 2002
    Tx
    Check the manufacturer's website or call them to find out exactly what kind of lug you need. Not all non-steel wheels use shank lugs, my alum wheels use regular tapered seat lug nuts.
    BDR
    Dec 2005
    BFE, Tejas
    Thats what my MT II wheels on my CJ use.
