Results 1 to 14 of 14
Thread: SeaFoam
    BeachJeepin
    Guest
    SeaFoam
    Anybody have any experience with this product? Any tips or suggestions about using this?
    i once heard that you could pull one of the plugs on your intake and stick a hose on there and put it in the can of seafoam and let it suck all of the stuff out. motor should die and let it sit for a few hours then start it. it will smoke a ****load and once it stopped you could drive it. its supposed to eat all the carbon buildup and shat. never tried it though
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    i use it alot, its some good stuff. i've use the engine treatment, you can either pour it in the gas or mix it with the oil. ive only used it in the gas. so far i have had nothing but good luck with it. you should be able to notice a difference after you run one through your first tank. they make a trans tune, and a penetrating spray. the penetrating spray works pretty well also. never tried the tranny stuff though
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
    BeachJeepin
    Guest
    tranny stuff says its for auto trannys. yeah it says to put 1/3 in tank, 1/3 in throttle body, and 1/3 in engine. I'm worried about it messing up seals in the engine... Heard nothing but great reports on it though
    you put it in, let the engine die, wait 10 min, start it back up, wait another 10 min, then drive the smoke out of it...
    Nov 2005
    Bayou Vista
    i've never ran it through the throttle body, but i have done essentially the same with spray carb cleaner. i know people that have put it in with the oil and never had any problems with messing up the seals. but if your just wanting to clean out the injectors then just dump one can per tank of gas
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    I used it in the blazer once while in the parking garage. Dumped it straight into the throttle body while it was running. All I remember is smoking out the entire parking garage with white smoke.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    to get best results, take the can and unhook a vacuum line from the intake like the one that goes to your brake booster, and insert this in the end of the can and let it suck up the can, you can either then kill it, or the engine will die out, then let it set for a couple of hours, the start that bad boy back up, i have can rolling around in the back of the f-350 but havent taken the time to put it in.
    Dec 2005
    BFE, Tejas
    where do you get this stuff and what does it look like?
    Seafoam won out in the snakeoil shootout of '05
    Wylie, Tejas
    I thought Marvel won the '05 shootout?
    Hazaa Fredo's Avatar
    I think Marvel won the shootout of '04.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    viva la seafoam, you can get it at vatozone, ho'rieleys, and associated parts places....
    with your mom
    Sea foam is the ****. It will evenb make a piece of crap caddy run good for a day or two. Frick is right the best way to use it is through the vacuum line at the brake booster, i usually just pour 1/3 of the can in slow then run it for about 10 min after that. Works great in the oil but u have to replace it after about a week cause all the carbon it breaksd down can **** up the bearings.
    Aug 2002
    yup if I think about it I'll usually pick up a can and pour half in the tank and half in the crankcase an hour or so before I do an oil change to help get the junk out. Chevy of course, not Yota. Who knows what kinda leaks would open up if I got the junk out of the Toy
