Results 1 to 6 of 6
Thread: Jeep Fix
    Registered User nickas's Avatar
    Oct 2006
    College Station
    Jeep Fix
    Figured I would start a thread before I tear this thing apart and get everyone's opinion on whats best options.
    Specs:
    1987 YJ
    4.2L with Motorcraft 2100 carb
    3.07 gears
    new Autometer Gauges
    Peugeot BA 10-5 Transmission with no reverse
    Future upgrades:
    new trans
    lower gears
    spray in bedliner
    front bumper
    I want to keep this jeep simple, but i want to fix it right without going broke.
    Right now i need to look at transmission options. A while back the transmission started clicking/poping while backing up. Gears 1-5 work fine. Now it has completely lost reverse and just grinds. Occasionally it will pop out of reverse when you let the clutch out, usually stays in gear, and grinds.
    I am about to pull the transmission and split it open, but should i fix this trans or spend the money for an ax15? Are there any other options?
    Nick
    '76 F250 High Boy
    '87 Wrangler
    Oct 2006
    College Station
    Transmission mount wore out and caused the skid plate to wear a hole in the t-case.
    Nick
    '76 F250 High Boy
    '87 Wrangler
    Oct 2006
    College Station
    Does anyone have a bellhousing to an ax15 for sale? Or know where I can find one.
    I have a rebuilt trans and a new rear cover on the t-case. The bellhousing is the only part I still need to put this back together.
    They should have come in 91-99 Cherokee and yj with a 4.0 or 4.2.
    Nick
    '76 F250 High Boy
    '87 Wrangler
    clutch changed sometime around 1995 from internal slave to external
    Oct 2006
    College Station
    Ya it changed, but I've seen some that use the same housing. They have a cover over the external cylinder mounting surface with a smaller hole for internal lines. Just remove the cover and it works for external slave cylinders.
    I am switching over to an external slave cylinder. So, 95-99 will definitely work. Some 91-95s will work. I think some newer ones will work too. Does a NV3550 have the same bolt pattern as the ax15?
    Nick
    '76 F250 High Boy
    '87 Wrangler
    MR.ZAP's Avatar
    San Antone
    I am about 90% sure that JP did a write up on a Jeep very similar to this one not too long ago.
