get a tape measure and measure the length between the front and backsides of the tires. get them even at first and then toe in each front tire 1/8". that what i did and it worked pretty goodOriginally Posted by Seth
1976 F-100 Kustom Krawler
1976 F-150 Custom
1964 CJ5
ok guys - its a driver. it floats big time, gonna have to get used to that. we put shocks on, welded a shock tab on, and ground down the inserts to get them to fit. went and got the new ends on the lines (FREE!), put those on and bled the brakes. trimmed the k member, cotter pinned the steering, aligned it a little more. Had to grind on the calipers a little to get the brake lines to fit. Put some new winshield wipers on it. That was all today.
yesterday and last night we drilled and bolted the track bar bracket, set the track bar length, picked up and installed a new yellow top, took my TTB to tates shop and disassembled it with the impact.
Still plenty of little things to do (insurance, registration, inspection, exhaust, some hardware, etc.) but it drives!!
Sorry for the lack of pics, I will try to borrow my roommates this evening as mine is on the blink.
Seth Stewart '04
2000 Suburban DD
1998 GMC pickup - sold
1975 Scout - TBD
1976 Scout - parts truck
1972 IH 1310 dually - TBD
196? Scout 800 - 302 roller
By the way, can someone change the name of this thread to "B.W.T."? With the new lease on life it got, I figure it can have a new name as well.
Seth Stewart '04
2000 Suburban DD
1975 Scout - TBD
i saw that it changed directions in the driveway
1976 F-150 Custom
1964 CJ5
kick ass
hell must be frosting over
can i come get the pitman arm tonight
Ryan Clarke
(214)695-7901
Wow if only Tate could work this efficiently on his own truckOriginally Posted by Seth
my truck needs a "little" more work than his did... i do more than that on my truck each time i work on it... it just needs more....ass
... and me tooOriginally Posted by CheapJeep
So I have been driving it for a week now. Functionality wise the biggest thing I need to fix is the spring bow. I need to get it in check enough that they don't hit the tires. I put a new throttle position sensor in and it idles normally again now. I actually had autozone read the codes for me and it threw the tps code, so I went to advance and bought one ***. inside the upper plenum and manifold side of the throttle body are pretty nasty so I am gonna sea foam it just for grins. Now that the idle is fixed it reminds me how badly i need to regear. with it idling high it preloaded the converter and acceleration was nice ***. all for now i suppse.
Seth Stewart '04
2000 Suburban DD
1975 Scout - TBD
oh yeah - i will go grab my roommates cam and click off a couple right now.
Seth Stewart '04
2000 Suburban DD
1975 Scout - TBD
heres a few
Seth Stewart '04
2000 Suburban DD
1975 Scout - TBD
more
Seth Stewart '04
2000 Suburban DD
1975 Scout - TBD
