Doug' right, I didnt see the comment bout underdrive. Since IH motas were known as tranny killers why is this even an issue?
lets say its a doubler. then a puny 300ftlbs becomes 600ftlbs.
but its not a doubler...same principal though.
The Ranger Torque Splitter is an auxiliary gear box that bolts in front of the standard Chevy, Ford and Land Cruiser 4 speed transmissions. This fully synchronized unit allows you to split your gears at any time. Just push in the clutch, grab the Ranger's shift lever, (You will have two shifters: one for your main trans and one for the Ranger) and shift. At any speed. The unit is available in either a 27% overdrive or a special order 17% underdrive.
they make one for a t-18 but in that case i dont understand the aluminum adapter for the d20. thats whay i say its a chevy trans.
I've never seen a SM420 so I dont know what they look like but that looks close enough to a SM465 that I would venture to guess thats what it is.
I thought an sm465 has 2 PTO ports. that tranny has only one.
I say it's a sm420 by the looks of it w/ the tall shifter housing. does it have three little cast in shift linkages on the top? should look like a roll of nickels cast into the top.
Yah 465s have two PTO covers like I said earlier I meant I would assume its a 420.
but it s a 420. see the big bulge on the pass side.
Lots of trannys
The snout for the shifter doesn't look like any of those
1988 Blazer...RIP
john, you suck at the internet!
If it's a 420, it's got to be a real early one.
i thinks its a 420. 2wd or 4wd before adapters?
420s were only 2wd. The adapter would be aftermarket, the the 420/adapter/t-case would be well worth the work of unbolting from the ranger and putting on the ebay.
