Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: wd40 alternatives
    Brazos County
    wd40 alternatives
    What do you guys use for rusted bolts etc. (i was going to say penetrating lube, which would have been correct, but you know...)
    I have wd40, and then i got a couple things from work, nutcracker, and seafoam - i am gonna get some stuff called general gel next - anyways - what do yall use , or what has worked for yall?
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
    Wylie, Tejas
    pb blaster!
    Boats and hoes
    Registered User
    May 2003
    Htown
    krebs had ballisto-lube. But it was like $3.50 a can and since it was krebs it should've been called ballisto-joob.
    It was all-natural sh!t, you could use it as insecticide and stuff it was wierd. Oh yeah and krebs was a joo about using it.
    So you loose, I win!
    Oct 2002
    Poth, Tx
    pb blaster!
    Shaggy
    twister
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    blue flame
    Registered User texasxj's Avatar
    Sep 2004
    St. Hedwig
    zep 45 or pb
    Clayton Rollins '08
    210-863-1435
    2007 Dodge Ram 3500 4x4 5.9
    1983 Waggy
    VW Ninja Jackasic's Avatar
    Jackasicstan
    the smoke wrench
    Brazos County
    im tryin to get my pitman arm off so torch isnt really an option
    Seth Stewart '04
    2000 Suburban DD
    1975 Scout - TBD
    Nov 2002
    Tx
    Quote Originally Posted by Seth
    Yes it is
    BDR
    hey seth...we use penetrol next door. it is made by shaffers so i dont know where you can get it but that **** works like no other...
    Steven W
    02 Dodge 2500
    Jan 2006
    DAAAnngerrr Zone!
    We use MP by Amsoil. It's hard to find being a dealer only sell, luckily g-pa is a dealer. Gonna put the Amsoil synthetic in everything; axles, tranny, tc, and engine. It makes a world of difference.
    'Cause if she don't,
    Aug 2002
    Seth are you trying to get the bolt off the sector shaft or actually pop the pitman off? If you're having trouble popping the pitman off, put the puller on it and get it as tight as you can, so it looks like the puller is about to break, then whack the pitman arm on the backside with a hammer (like hit it on the side opposite where the arm reaches out, so you're putting impact on the splines). Should pop right off.
    Aug 2005
    Houston or a drag strip
    For solvents I've always used some of the blue John Deere breakdown stuff.
    Impact+pitman arm puller= success.
    1974 CJ5-The BarnBurner
  15. #15
    Registered william_ace's Avatar
    Feb 2004
    College Station, TX
    what?? you used up my wd40 already? did i leave my bucket there at your place seth?
