Page 59 of 67 FirstFirst ... 9 49 55 56 57 58 59 60 61 62 63 ... LastLast
Results 871 to 885 of 1000
Thread: Beast from da Middle East
  1. #871
    Quote Originally Posted by agjohn02 View Post
    Do they carry that at Napa? E8248s are supposed to flow pretty well and be available.
    don't think so, but I bet a good speed shop would have one. Easily adapted to -8 fittings and should futureproof the fuel system to whatever long term big block plans Ed may or may not want to talk about on this board.
    there are alternatives if you are in some sort of survival mode with the beast as your lifeline
    you sure its not a quick connect? if it is a barb, cut off the barb and put a compression fitting on it. its a barb on the high pressure side?
    thats the sort of kludge that this will be eliminating.
  2. #872
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    i wouldnt call that a kludge if it made it an option to get a readily available fuel pump when the current one goes out. i put something very similar on the scout tank 5 years ago and its been bullet proof. i find it hard to believe its a barb on the high pressure side anyhow.
    edit- just noticed you have a pic. cant see it at work.
  3. #873
    Yah, its a barb. This is what it looks like
    I ****ing hate compression fittings but might end up having to do that for a little while until I can swing the 044.
  4. #874
    Apr 2004
    Cowtown
    if thats the case, then I'll just have to give the ol' e2000 a try on the jeep when i get to it.
  5. #875
    Hazaa Fredo's Avatar
    How much is the 044 in comparison to an E8248 or E2000?
  6. #876
  7. #877
    Is this a baller AN version of a compression fitting?
    http://www.jegs.com/i/JEGS/555/10538...oductId=752568
  8. #878
    Apr 2004
    Cowtown
    like this:
    http://www.summitracing.com/parts/EAR-165056ERL/
  9. #879
    For roughly $100, I could still sleep at night knowing I used a compression fitting.
  10. #880
    Yah I'm leaning more towards it.
  11. #881
    Ed those valves showed up too, I don't know about this idea. I think a shower of gas is a good thing once in a while.
  12. #882
    Oct 2002
    Poth, Tx
    There is no high pressure, it's less than 15 psi. This is assuming it still uses the stock tbi built in regulators. I slip a hose over it and use a hose clamp.
  13. #883
    The 044 pump operates at 70+ PSI, and Ed's truck has an external regulator on it.
  14. #884
    Mar 2009
    What are the valves for? fuel cutoff?
  15. #885
    Apr 2004
    Cowtown
    normally, when someone talks about plumbing a vehicle, they arent referring to house plumbing.
