im going torch my piece of ****
1976 F-100 Kustom Krawler
1976 F-150 Custom
1964 CJ5
I've been working on jeep since noon. Maybe come over to talk **** and drink beer after I put the steering box back on jeep.
Is anybody gonna have a welder fired up. I need one rod to weld an upper control arm bracket back on tonight or tommorow.
i have two
Ryan Clarke
(214)695-7901
Well i'll give you a call when i get it back together and head over.
BTW, if you'll are going to bring it back by, do it later in the day, like after 6pm. I'm pretty tired, so I'm just going to crash when I get home this morning, then get up when stef leaves for work, and then go work on the buggy. Don't worry about the dremel tool, as I'm just going to yank the axle housing back out and worry about it this summer. None of you would happen to have a little propane or mapp gas torch, would you? I need to pull 2 studs that have red locktight on them, and eric seems to think heating them up is the best method to get them to loosen up
If you would have to bring the pipe bender back earlier in the day for some reason, just throw it in the back of my tacoma under one of those boxes.
according to the loctite rep that gave us a 2 hour presentation on all the wonders of different loctite products, heat is the only way to take it apart.Originally Posted by CRaSHnBuRN
Steven W
02 Dodge 2500
is anyone working tonight?
Ryan is working on his cage right now.
cool stuff
cage is finished, bumper finished, all the lines are gone and the cheap is only a axle short looks like we're going to make no problem
p.s. cages suck balls
Ryan Clarke
(214)695-7901
Me and ryan are bad doods when it comes to notching tube with a torch and a grinder. Ill have pics up in the next 2 days.
The highlight of the weekend was ryan's roomate calling us to come put his tire on his 72 caddy in the middle of university at 11 pm. the damn thing just fell off. Cops had 2 lanes blocked off, It was a sight to be seen!
me bring bronco over tomorrow to start my extended work weekend, got the arms done and installed, but i must have screwed up the measuring some cause the axle is about 2 inches forward of where its supossed to be, and the coils are getting pissy. Yet, on a good note this arms flex like some bad mofo's i had ryan huge arse high lift all the way up to almsot the very last hole and the axle was still firmly planted on the ground and the truck was suprisingly stable
