Rover is a cool unique vehicle, Waggy is cool too.
In case you do decide on the Waggy, heres a good source for parts. www.bjsoffroad.com
95 Land Rover
83 Wagoneer
If your moving it back just an inch or two you can use the stock upper spring mounts. You'll need new lower links and a lengthener for the upper A-Arm. all it does is set the upper ball joint at more of an offset. More than that and you'll have to fab upper and lower suspension arms along w/ upper spring mountsOriginally Posted by 95discovery
www.rovertym.com
look around this sight for springs and suspension links...whatever you do do not by the spring retaining cones. They suck. All they are good for is to pump up your RTI score.
Each one is unique. You don't see many waggy's driving around, nor do you see an abundance of Rover's. Cost is going to be the main factor, how much are you wanting to spend on parts. The waggy will be much easier to find parts for and upgrade, but you'll be looking to drop some skrilla on the interior. Just choose which ever one you think you'll be more happy with.
ive looked aroud on their site a few times but never saw the a-arm extension, looks pretty cool. I already have the 3" OME springs, are the rte springs any better? Also im not sure if i fully understand how that moves the axle back. If the upper spring mount isnt moved back wont it go back to the stock position when the tires are stuffed? Just seems a little wierd, but what do i know. One more thing, how far would the axle have to be moved back to fit 33's without having to cut into the door... if thats possible at all?
well your name on here is just gonna be weird if you sell the disco... it is like if i cut my shaggy hair.... wait
I voted rover -
while the waggy could be made into a cool dependable daily driver - i think the disco is better. rover is gonna be better on the highway. rover has no rust - i hate rust - also no rusty bolts. if its going to be a true daily driver then the rover can do that type wheelin
Seth Stewart '04
2000 Suburban DD
1998 GMC pickup - sold
1975 Scout - TBD
1976 Scout - parts truck
1972 IH 1310 dually - TBD
196? Scout 800 - 302 roller
I'm probably not a good person to listen to anyways, as I'm currently talking with a guy about buying his 1979 Jeep Cherokee Golden Eagle.
their springs come in more rates and lengths. also you can get progressive or linear rates.Originally Posted by 95discovery
if you lengthen the top mount and bottom arms, then the axle is moved back. the spring on coil sprung vehicles does not locate the axle. In fact, the only thing keeping the top of the spring in the perch is your shock length, or lack of it. It's not ideal, but it will work for that little bit of lengthening.
Can you fit 33's? Depends on what width. If you get a tire that will clear the fender lip, then yes. You will have to trim the rear of the fender where it wraps underneath at the bottom. Also, if you already haven't, you will have to roll the lip on the body shell that outlines the curved part on the rear door opening (the door jam). It takes a big pair of good channel locks to do it. I run skinny 32" tires and they clear fine on my RR. If 33" tires don't clear, you can always lengthen the shock w/ a new shock mount and put in a taller bump stop to get more down travel (droop) and eliminate some of the up travel (stuff). This would make the ride worse though and probably cause some un-weighting of the tires IMO w/o a lot of other mods like longer links etc.
lots of rust means any attempt to make that ho nice will be futile. Do you drive a lot or a little? Are you ready to drive a POS for the next few years? If you think you are, I'll let you DD the ugly truck for a week or so and you can rethink whether you want to lose the option of driving a nice vehicle when you want to. I am 100% against anybody planning to do hard wheeling in their DD (ie anything you think you need 35s for). When you hit that point, get something small and tow it to the trails. *cough*sammy*cough*
please don't trash your nice car
wow Eric, nobody told me not to wheel a DD hard, guess ill figure out sometime
yeah but you started ****ing yours up when you had 31's, so you are against the learning curve and dont count, or something like that.Originally Posted by AggieTJ2007
search NEWB!
hmm, now im kinda getting the feeling to keep both, leave the rover as it is for a DD (maybe some 32" m/t's) and build the jeep as a trail vehicle so i dont have to worry about breaking stuff as much. The only thing is that i dont have a trailer and that could be a slight problem. too many damn decisions and not enough money. Or i guess i could just wheel the rover until i know what im doing then start building a bigger rig.
Just get something small and flat tow it behind the rover.
