Page 29 of 30 FirstFirst ... 19 25 26 27 28 29 30 LastLast
Results 421 to 435 of 439
Thread: Krew Kab Klogger
  1. #421
    Ordered my driveshaft stuff from Ontario Engine & Machine:
    http://www.ontarioengine.com/
    They had the best price on the shaft/sleeve - $175.65 for the shaft and sleeve
    At any rate, I ordered it a little over a week ago and had not recieved, so I called the number. The owner/manager Vic Logan answered. Super nice guy, he remembered the order just by me saying I ordered a long travel spline and some 1410 stuff. Was able to find it without me even telling him my name. He looked it up, its due for delivery today. I then spent 25 minutes asking him questions that he answered completly. Even gave me tips on how to machine some of the stuff to work. If any of you guys are going to make a long travel, I would use them for parts or the entire shaft.
  2. #422
    Mar 2009
  3. #423
    F' that radius armed ball joint 60 pile of parts. Granted his fab is better than mine, but the klogger will out wheel that thing any day. I was going to do a radius arm thing similar to what he did, and for the time the leaf springs took, I am glad I went the way I did.
    And don't forget, Klogger Kab Version 3.0 is coming in 2013!
  4. #424
    Mar 2009
    Give me a call if you want a hand.
  5. #425
    Oct 2002
    Poth, Tx
    Certurion conversion this time?
  6. #426
    Sand Man Shaggy's Avatar
    Dec 2007
    San Antonio or Victoria
    That would be awesome if it had a full size bed/ fold down back seat like my dads old truck.
  7. #427
    Got my driveshaft made. Picture here shows the parts, Starting from top right, going left 1) 1350 weld yoke, 2) piece of 2.750" 0.250" wall DOM tube, I had to ID bore the tube on my Dad's lathe to make it fit the yoke, 3) Splined sleeve that I turned the OD and cut in half, this acts as the bushing between the tube and splined shaft. I welded the splined yoke to this piece and then this piece to the tube.
    Next middle level is the Neapco shaft (part 4) and sleeve (part 5) listed in posts above. The splined section is 25" long, the sleeve is 6", it is made on the far left side to fit a smaller tube, but I used the larger diameter and turned it to fit in the tube.
    Bottom row: 6) more of the 2.75" X 0.250 tube, I had to turn the OD down on the end of this, the wall was like 0.180 when I was done finally 7) is a 1410 weld yoke, I bored the ID on the mill to fit the OD of the turned section of tube.
  8. #428
    Finished product, at ride height 39.25" long with 7" up travel slip, 10" down travel slip, 1410 yoke on T-Case side, 1350 on axle side. Welded together on the highest setting my mig will go to.....Name:  Northeast Harris-20121205-00086.jpg
  9. #429
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    Pretty slick! So under $200 for all of it?
  10. #430
    Quote Originally Posted by davido View Post
    Ha! under 200 for the slip shaft and sleeve....
  11. #431
    Oct 2002
    Poth, Tx
    You know you wouldn't need that **** if you just put a proper suspension under it.
  12. #432
    I am pretty sure proper suspension will not fit under the giant Ford cross member, I had to clearance it a lot for hydro-assist.
  13. #433
    Nov 2002
    Tx
    Quote Originally Posted by eight View Post
    you know you wouldn't need that **** if you just put a proper suspension under it.
    TTB?
  14. #434
    Mar 2002
    College Station, TX
  15. #435
    Rawr TexTJ209's Avatar
    Waco, Tx
    King Krew Kab Klogger?
    '81 CJ7 Laredo, 258/T176/D300
