Originally Posted by
CRaSHnBuRN
maybe. It is pretty shallow on the top. When I tapped mine, the tap barely got any thread engagement before bottoming out, so I would tap a little, grind the tip of the tap off, the tap a little more until I had good thread engagement. I cleaned everything up, then before reassembling, I put a piece of wire in the port (or whatever the tube was I tapped to) then tightened up the fitting just to make sure I didn't close it off like you think you did.
Could it be that your pump is unable to keep up? I drilled out a port on the toyota pump to up the flow, and that seemed to help alot
