Results 1 to 14 of 14
Thread: Heims or TRE's
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    Heims or TRE's
    let's hear both sides. Pro's and con's...
    chevsu
    TRE's they stay tight. steering or susp.?
    Aug 2002
    trying to set up for an active day on the boards?
    Apr 2004
    Cowtown
    steering. wouldn't use TRE's on suspension personally.
    nah, im gonna be busy today, but i figured this would be an active thread since some people are so passionate about heims. i personally like TRE's for the same reason cody stated plus they are greasable.
    now if you dont have anything productive to say, get off my thread hippie.
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    I went with TRE's for my steering cause I figured if the manufacturers though TRE's are better, then they probably are.
    Aug 2002
    Quote Originally Posted by agjohn02
    bite me
    and you can get greasable heims, but they suck...good ones have teflon. You already know you're gonna use TREs. You trying to join the chadnutz/robbie club?
    Apr 2004
    Cowtown
    no, im trying to be open minded and get all the input i can before i make my final decision. you should be happy.
    Aug 2002
    okay, my impression is that if you are going to have crazy amounts of flex and your steering will need to accomodate large amounts of misalignment, you should go for heims at the expense of having to keep an eye on your steering and check the tighness of the joints and the bolts. Billavista did a writeup on heims and rod ends I think, read that and let us know what you find.
    My experience is that cheap heims suck and wear out quickly. My first set got super sloppy in like 10,000 miles, and replacing (2) with expensive teflon ones made a world of difference.
    Aug 2004
    Corpus Christi
    Drag link ends have alot more misalignment than TRE's, why not use them if you need more travel?
    Oct 2004
    Headed back to the Big D
    hmm, good point there robert. I went w/ TRE instead of something w/ heims because on the street the TRE will last a lot longer and they stay tight
    Apr 2004
    Cowtown
    in my head at least, TRE is a generic term for OEM style joints. which technically, would be TRE on the the tie rod and DLE on the drag link. so yeah...
    Apr 2004
    Cowtown
    you can buy new cheap ones already worn out, right kopecki?
    Aug 2005
    Houston or a drag strip
    I run heims on my drag link with no problems so far, but I do agree that tre's are alot easier on the maintenance side of things.
    1974 CJ5-The BarnBurner
    Jun 2005
    still it's not as much as a heim with misalighnment spacers. I think either way can work good, you just can't buy 10$ hiems.
