Results 1 to 10 of 10
Thread: 89 xj 4.0
    Sep 2004
    89 xj 4.0
    will die randomly at times. will start then immediately die again. will run when the air filter is pulled out or put back in if its already out. it will start with ether. i think its a fuel issue. tps or some sensor like that?
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    Dec 2002
    Austin, TX
    if it was tps, it wouldnt even let it start, its either on/off
    it'll start with a bad or unhooked tps
    i'd check fuel pressure, then hook an ohm meter up to the tps and check it out
    I know from first hand experience that the HO's don't idle right with missing o2 sensor or VSS. Not sure about the regular 4.0
    or you could wait until football season starts and I'll bring the flemco DRB2 scantool in town
    edit: I just read the part about the air filter, sounds like your IAC is gummed up or broken. take it out, clean it w/ b12. Do you have oil blowby? that can cause them to get crap in them.
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    Hey queermo I have a OBDII scanner at mi casa, it maybe help?
    Sep 2004
    oil finds its way through the valve cover vent to the air box and soaks the filter so that could be it. where is the iac? i don't remember seeing it when i was looking at the air box etc. scanner may help; not sure if its throwing codes or not. the speedo works so i guess the vss is out.
    its a friends jeep here in dallas.
    1976 F-150 Custom
    1964 CJ5
    Hazaa Fredo's Avatar
    This cherokee isn't Maaco Yellow is it?
    A guy in the club had a non-HO 4.0L that when we plugged up the PCV Valve line that goes over to the air cleaner, it built up so much backpressure that when we twisted the oil cap to take it off, it sounded like a bottle of coke opening. You could also just set the oil cap in the hole while it was running and it would whistle like a tea kettle.
    fbronco86
    Quote Originally Posted by RCook527
    try changing the fuel filter?
    89 won't throw a code if something is messed up, no on board diagnostics.
    Sep 2004
    i did change the filter. i'll check the pcv valve, maybe thats forcing oil into the air box.
    1976 F-150 Custom
    1964 CJ5
    Sep 2004
    yea. doesnt have a pcv valve. has something called ccv. couldn't find a iac sensor either. that leaves me with the tps or map sensors. pulled the ccv rubber plug on the valve cover and it looks like someone dumped coffee grounds in there.
    1976 F-150 Custom
    1964 CJ5
