I took a c-clip off just behind backing plate and pounded the **** out of the plate with a hammer but I can't get the shaft out. I bought it at a junkyard for a spare. What's the trick?
c-clip behind the brake backing plate? Sounds like you mean bearing retainer, not c-clip.
I've seen some that have zero clearance on the bearing and you pretty much need to remove (and replace) the axle bearing to get the backing plates off.
Sounds like Garrett's 9" where we ended up having to use a fire hydrant as a giant slide hammer and ended up destroying the bearings. Have fun.
just use a bigger hammer
Tommy Matheaus '06
210-323-2546
2004 F-140 4x4 DD
1990 F-150 4x4 in the works
what kind of axle.
i had to use a hi-lift between the spring and backing plate to get the shaft outta my dads amc 20.
I'll give you 3 guesses and one of my rear axles is full floating.
only one... how many rear axles you got?
a spare tire with a chain works good
Two...
I'll just use a press I guess...
unbelievably, yes it did.Originally Posted by J Cooper
John, is that an approved use for a high-lift
Boats and hoes
hell yes it does. thats how i've pulled my 9inch shafts. im about to go do it again here in a little while, because the traclock blew up on my way to the tire shop today....Originally Posted by J Cooper
1976 F-100 Kustom Krawler
1976 F-150 Custom
1964 CJ5
i have no ****ing clue. i was going in a straight line shifting from 3rd to 4th and i let the clutch out and all hell broke loose.
1976 F-150 Custom
1964 CJ5
