Results 1 to 8 of 8
Thread: high idle
    Brazos County
    high idle
    So when I start my truck, it fires off and runs fine. After it warms up though it idles high. I would guess around 2000 rpm. I know that this is pretty broad, but anyone have any idea what that could be? I still have to put the exhaust back on, that is the only thing that has changed. I would guess bad gas or fuel filter, but it runs fine for a few minutes cold.
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
    Aug 2002
    vacuum leak, or your open exhaust is messing with your 02 sensor. I wouldn't mess with it until you have your exhaust back together
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    i would say that it is tryin to compensate for the o2 sensor, the first few minutes the vehicle is running it bypasses the sensor, then after the motor is warm it starts to reading that sensor
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
    Sep 2004
    Quote Originally Posted by TMatheaus
    o2 sensor
    concur, ecm doesn't like it when o2 sensors aren't reading what they should. it might be in 'limp home" mode
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    Brazos County
    i thought about that....the o2 sensor is there, it is just before where i cut off
    Seth Stewart '04
    2000 Suburban DD
    1975 Scout - TBD
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    Quote Originally Posted by Seth
    doesnt matter, its still getting oxygen from outside.
    sounds more like an idle air control problem
    Brazos County
    thats what me and a guy here at work were just talking about. i dont know if the egr would do this, but it is disconnected too.
    I am going to check our comp here at work and see if it has a trouble shooting menu for this.
    Seth Stewart '04
    2000 Suburban DD
    1975 Scout - TBD
    Nov 2005
    Bayou Vista
    i had a problem with the idle air control valve on my truck, it would run fine, drive fine, but when i went to stop the truck would stay idled up around 1500-1800, replaced that and havn't had a problem yet
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
