Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Thread: School me on hyro-boost systems
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    Alright my brakes suck cause my cam is to big, and i like theway the truck sounds so i am looking at other options. Right now hydro-boost seems like the best option. the only thing i am leery about is my pump dying and being stuck with manual brakes. i realize i could carry a spare pump, and solve this problem.
    1 how much are we talking to do the swap?
    2 what trucks do i need to get parts from
    3 What companies make upgraded good pumps to be able to run my hydro assist steering, and brakes.
    discuss
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    I dont remember what it came out of but Garrett has hydroboost on the b-ronc and likes it alot. I want to say a lincoln towncar but that doesnt sound right. Look in Ford diesels, fullsize vans and 1 ton pickups. You most deffinately need it and I'm sure the trees in Clayton would thank you.
    As far as pumps go, saginaw all the way. Even with a saginaw pump with the high-flow mods done to it, some people have had mixed reviews while using hydro assist and hydroboost brakes. For some it works, for others it doesnt but you might want to consider using a 1 1/2" ram instead of 2" so it doesnt require as much juice. You will deffinately need to figure out how to add some fluid capacity, but that isnt very hard. That guy willyswanter on pirate and ck5 runs two saginaw pumps, one for steering and one for the brakes.
    I wouldnt expect the entire swap to cost more than $200, and thats if you go balls to the wall and swap in a saginaw pump and get a decent deal on the booster and master cylinder. I have been told that if you lose the power steering pump, the goofy little cylinder mounted off to the side on the booster unit is designed to hold enough pressure to allow you to brake normaly 2 or 3 more times. I know this as a fact, cause at Alto I lost my PS belt and was still able to stop normaly once or twice.
    Quote Originally Posted by stx4wheeler
    discuss
    Astro minivan seems to be a popular and plentiful donor for the hydroboost swap.
    1988 Blazer...RIP
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    its just for one power assisted stop
    edit: i think
    Sep 2004
    the bump on my forehead says your brakes suck dong as well. how often do ps pumps honestly go out? i know you can add a reservoir no problem to the return side. could you add a reservoir to the high pressure side and would it help with pressure issues? also wasn't your first ram a 1" bore? sharpes right, a smaller ram will cut down on the pumps work.
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    first ram was 1.5 inch. im going to 2 inch cause a welded front is gonna require more force to turn easier.
    i have a saginaw pump already assuming it is working? sharpe?
    garrets crapped out and was a junkyard pump jsut like the one i have is so i figure i nned to find another back up pump, or get a new one now, and then use the one i haveas a spare.
    Aug 2005
    Houston or a drag strip
    I'd find a pump in good working order and maybe add a high capacity remote reservoir because that's alot to ask of the pump. Then again I'm welded in the front and have been using a Rolls Royce pump and it hasn't blown up yet...but we'll leave that alone. Speaking of which I need to get to work on my own hydro assist and swap in my saginaw pump now that I got 38"s.
    1974 CJ5-The BarnBurner
    Aug 2004
    Corpus Christi
    My well since you already have a saginaw you're set there. I personaly have never seen a power steering pump fail, I dont remember if Garrett's actually failed or if he just wanted to swap it out for a saginaw. The pump I originaly had on pigpen was leaking, so I went ahead and bought a $30 reman pump, but I destroyed the pulley trying to get it off because I didnt know what I was doing and ended up beating the entire pulley/pump/reservoir/bracket assembly into a metal blob with a 3lb sledge cause I was pissed off. So if you plan on carrying a spare, make sure you have the special pulley remover.
    Putting a reservoir in the low pressure side doesnt sound like a very good idea, the pump sucks **** directly out of the reservoir its mounted in so for some reason that just doesnt sound like a good plan. A reservoir on the high pressure side sounds even worse.
    You can try a 2" ram, but I would still recomend a 1 1/2" from what I've seen. A little extra exercise never killed anyone anyway.
    True Hollywood Stry
    Sep 2003
    somewhere in texas
    i also have a power steering cooler to help with more fluid and less heat.
    Wylie, Tejas
    I don't see what a reservoir on the low side could be a bad idea? It may not need it, but I don't see how it could hurt anything. A cooler is a great idea, the bigger the better.
    Boats and hoes
    Sep 2004
    1976 F-150 Custom
    1964 CJ5
    Dec 2005
    BFE, Tejas
    Look in summit for the hi-cap electric vaccum pumps and resivours for race cars, i bet that may be a cheaper and less complicated idea
    Aug 2004
    Corpus Christi
    While yes a cooler is always a good idea, they do not add to reserve capacity (i.e. the reservoir will still be sucked dry just as easily) I suppose a reservoir in the low pressure side might work but it seems to me like the fluid is "pushed" back into the primary reservoir out of the low side. If you had a second reservoir before the first one, what would draw the fluid from the second reservoir to the first? I doubt the pump creates sufficient suction to do the job and I wouldnt want to rely on gravity (this is on the pressurized hose, gravity is ok on a remote reservoir...thats what pigpen has). If you get a normal style reservoir, you can hose clamp a piece of radiator hose to the top to add more capacity, and if you run a remote reservoir you can just cludge something together.
    Shaggy
    that is pretty clean looking... i like the idea
  15. #15
    Apr 2004
    Cowtown
    blah blah blah
    i couldnt read all that dribble
    a remote reservoir will help in that it will up system capacity, aiding both cooling and flow requirements.
    remember, the cooler and reservoir go on the return/low pressure side. nothing should be between the pump and box. got that chadnutz?
