I have Hydroboost on the suburban (1996 K2500 w/ 7.4L, 92,000 miles). The pedal is stiff right when you press it and seems really stiff when you jab it. Also, if I'm turning a slow curve and hit my brakes i get feedback thru the steering wheel like loss of power. I've also noticed that the steering is stiff in parking lots when i hit the brakes and turn. I replaced the pump w/ a rebuilt one, the master and all the calipers, pads, shoes, wheel cylinders, drums and rotors are new. I think it may be the accumulator. B/c I do not have power brakes after the ignition is shut off like your suppose too. Are the above symptoms of a bad accumulator? Also, It seems like my back brakes aren't cutting in like they should. Do the proportion valves go out in these things. I've adjusted the shoes until they drag and the brakes still suck! ..and these are the big huge finned drums on 14 bolts.
Here's another question...if you have loose steering is it usually the idler arm or...? I have about 10-15* of play. It has 285's tires on it so this might have worn something out faster...any ideas?
