at least its only flat on one side
Originally Posted by agjohn02
actually both sides are, hehe...
no, i mean one side of the tire, the bottom side
gotya
as cheap as most sammi guys are, i bet somebody makes a spacer for that driveshaft
The wheel base is right at 85 inches, 5 1/2 over stock. a 1/2 more inch and it will be the same as my jeep.
does anyone have any toyota spring plates that they need to get rid of?????
I've got a few sets you can have if you want, but they are thin and the holes are kind of elongated. I would buy a set of plates elsewhere, or pull a set off a cherookie in a junkyard (I think you have to find one that had a dana 44 in it though, the ones with a 35 have the holes too close together for a toyota axle tube)
i will have a set off the rear 44 of the waggy when i start to rip it apart on sunday, you can come over and take them off and have them
were u located?
villa maria and texas, from your place keep going past texas, take a left at the light at wayside, down wayside past the first stop sign as soon as it curves to the left on the left. 2302 wayside
I had to change up the spring packs to get them were I wanted, So all of the suspension is done. I made new shackles out of .25"x2" flat bar, 1.5" longer to adjust the pinion angle.
It is currently supporting its own weight, but I need to finish the steering, driveshafts, some gussets, and brakelines to get it moving and stopping on its own. Oh yeah, and shocks and bumpstops.
looking good man
