Results 1 to 15 of 15
Thread: raised motor mounts
    lowballing someone
    Feb 2005
    Houstonish
    raised motor mounts
    ive been looking for raised motor mounts for the jeep(6 cyl) and can't find 2 or 3 inches all i have seen are 1 inch, and i need more than that. anyone have a link, or a pair sitting around
    Jun 2005
    is there even enough room to raise the motor 2 or 3 inches?
    lowballing someone
    Feb 2005
    Houstonish
    i'm doing a 2-3" body lift to clear the clocked transfer case so i don't have to cut/beat the tub
    so your drive train is going to be pointing up? ...and in a bind? what will that do to the front DS? Seems it would bind the front driveline up (at least decrease the angle)b/c by raising the motor you are pointing the front out put up. If you clocked the case to get the front output lower what's the point? you lowered your breakover angle then.
    Aug 2005
    Houston or a drag strip
    M.O.R.E. probably has em'.
    1974 CJ5-The BarnBurner
    lowballing someone
    Feb 2005
    Houstonish
    the point of clocking the tcase is so that i can make my flat skid plate, and since i'm moving the tranny and tcase mount up a few inches i need to do the same with the motor so that everything sits level and the angles for the f and r drive shaft are more normal
    Dallas, TX
    I don't think anyone makes a motor mount that's raised more than an inch. I'm pretty sure that'll put your front driveshaft in a bad bind...
    Oct 2004
    Headed back to the Big D
    why don't you just not clock the 300 up as far.
    lowballing someone
    Feb 2005
    Houstonish
    a posability, i'm going almost flat(just past where the tranny mount is) and as far as the motor mounts i know i saw 2" ones a while ago and that would make me happy but they seem to have disappeared off the market as far as i can see, if i can only find 1" then i might as well leave mine as they are
    Oct 2004
    1 inch does make a difference, but it might drop the case depending on how far past the tranny mount it is
    Oct 2002
    Poth, Tx
    I just put a little drop in my skid plate. Still got the drivetrain up a little from stock. That d300 unclocked is the real problem anyway. Raising it also gives more problems with short cj5 driveshaft.
    motor mount lift = ghetto, even 1"
    Brazos County
    yeah maybe it is a jeep thing - but i think this is the first time i have ever heard of anything like that
    Seth Stewart '04
    2000 Suburban DD
    1998 GMC pickup - sold
    1975 Scout - TBD
    1976 Scout - parts truck
    1972 IH 1310 dually - TBD
    196? Scout 800 - 302 roller
    lowballing someone
    Feb 2005
    Houstonish
    the raised motor mounts realign the motor and tranny in correct geometry after you go from a 3 inch drop or so skid plate to a flat one
  15. #15
    Registered User junior88mj's Avatar
    Nov 2003
    Lake Bryan
    make them use shackle buschings and pipe that they fit inside of and make them as tall as you want as long as guset them or make spacers to put under the 1" mounts out of 1"x1" heavy wall sqare tube
    junior burrell || 88 mj & 77 j-10->soon to be diesel & 79 amx & 68 javelin || amc rules !!!!!!!!
