Results 1 to 8 of 8
Thread: What size wire for welder extension cable?
    Tommy sucks Sharpe's Avatar
    Aug 2004
    Corpus Christi
    I need to make an extension cable for my welder but dont know what size or type of wire to use. I went to homo depot today and got the plugs but aparently knowing about wiring is not a prerequisit to working in the electrical department and none of the 'tards there could help. They had plenty of wire that was big but as expensive at is I want to do it right the first time. My welder is a millermatic 210 and the plugs that fit it say 250 volt 50 amp.
    how many amps does it actually pull? How long of a cord do you want? Both make a difference. You can probably find the info in the owners manual or online.
    1988 Blazer...RIP
    Oct 2002
    Poth, Tx
    8 ga minimum. 6 ga prefered. You should have bought it a year ago. Copper expensive now yea?
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    depends on what the circuit is rated at too. im run 10-3 and it works well. a 40' cord costs right at $100.
    i bet your 220v is 30 amp. is it a dryer plug with the right angle third prong?
    Aug 2004
    Corpus Christi
    I'm lookin to make one 20 or 30'. The plug looks like a bigass 110, 2 parallel blades, one wider than the other, and then a 3rd round one.
    go to central electric in bryan...one stop shop
    Apr 2004
    Cowtown
    check the circuit and see what the breaker is. thats a 50A plug.
    if its a 50A circuit use 8AWG. 6 would be overkill and a waste of money.
    lazy ass
    Seems kinda wimpy, but thats what the current model requires. For my welder the owners manual said it could use 14 gauge for 60'
    1988 Blazer...RIP
