Who can re-cut axleshaft splines?
I need to shorten a shaft. from my narrowed D60
Moser will do it for $65. Anyone closer or cheaper?
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
Damn, they are that cheap?Originally Posted by redcagepatrol
I was going to buy the tool to do it, but it's $150...
1988 Blazer...RIP
I looked up a few places on the web:
Dutchman - $55, in Portland OR
Currie - $120 pair, in CA
Scott, FTAC '99
Don't you have a cut-off tool? I've got a pretty steady hand...
Boats and hoes
id say thats hard to beat. splines are pretty technical and finding someone that even knows the terminology isnt easy. id have them do it.
rat tail file!Originally Posted by Reckless
but really, those are pretty good prices. The only other places I could think of would be D.D. Machine on pirate (the guy who built creightons doubler) or the guy who does all the cryoing (66cjdean or something like that)
what about techniques? do they both cut? any of them roll splines? that would be better.
Big Mike has all the tools you need to do that job. Just put the right angle chuck on the mill and hold the shaft and mill the splines in. The one right angle chuck has set postions on it. So you can turn it at certain degrees.Originally Posted by Doug Krebs
I really think the splines are broached from the factory.
I don't think you would roll splines on a previosly heat treated or work hardened axle. the machine to roll splines must be ungodly expensive, because u will be hard pressed to find any machine shop with one. I have used both currie and mosier for resplining, I think mosier does a better job the axles I had currie respline looked like they had been whacked of with a chop saw ragged edges and chatter mark's on the splines, I was not impressed.Originally Posted by agjohn02
Yes and no.Originally Posted by fbronco86
I know how to do it with the indexing head and the little wheels. Problem is he only has HSS cutters. If I was making a new shaft out of annealed material it wouldn't be a big deal. Trying to use the HSS on my shaft would cook it on the first touch. The shaft is ~60Rc.
So, the tool I need is $150 which can hold ceramic inserts.
1988 Blazer...RIP
Boats and hoes
I did not know the shafts were that hard.Originally Posted by Doug Krebs
You cound anneal it, machine it, and then harden it.
I'm worried about warping and tolerances. I have no experience in dealing with how much the dimensions will change, so I'd rather just do it the way other people do.Originally Posted by fbronco86
I'd probably have to buy and new cutter anyways as they one mike has is dull.
1988 Blazer...RIP
I would just pay to have someone else do the work much easier.Originally Posted by Doug Krebs
