Results 1 to 14 of 14
Thread: 727 problem, i think
    wh09p! 95discovery's Avatar
    Sep 2005
    1003 hardwood ln
    recently the jeep has been acting like a jeep. Once coming to a stop after running for a bit the engine will die. It sounds like a manual does if you slow down without putting the clutch in. Im thinking its the torque conveter locking up and not releasing. Any other suggestions?
    Sep 2004
    i concur
    1976 F-100 Kustom Krawler
    1976 F-150 Custom
    1964 CJ5
    Sep 2005
    1003 hardwood ln
    also forgot to mention that if you put it in neutral before it stops, then put it back in gear after it stops, itll idle fine.
    fbronco86
    Quote Originally Posted by 95discovery
    Sounds like the valve body is hanging up. Might try fluid change and a filter.
    D-FENS agjohn02's Avatar
    Apr 2004
    Cowtown
    i concur with mike. torque converters are more likely to not engage than not disengage. they usually make noise too.
    Oct 2002
    Poth, Tx
    727 got lockup converter?
    Sep 2005
    1003 hardwood ln
    Quote Originally Posted by eight
    aye
    and thanks for the input, hopefully ill get a chance to work on it this weekend or next, once all this school **** calms down. for now ill just drive it like a stick and put it in neutral every stop.
    ... TMatheaus's Avatar
    Nov 2005
    Bayou Vista
    put a can of the k&w trans-x in it, it might help free a valve if its sticky
    Tommy Matheaus '06
    210-323-2546
    2004 F-140 4x4 DD
    1990 F-150 4x4 in the works
    Sep 2005
    1003 hardwood ln
    well the fluid and filter was replaced not too long ago. One of the springs borke a while ago and just left shards in there, so thats more than likely the problem. I thought we got all of the pieces out before but i guess not.
    Rawr TexTJ209's Avatar
    Sep 2004
    Waco, Tx
    '73 J2000 Thriftside Gladiator, 258/T14/D20
    '81 CJ7 Laredo, 258/T176/D300
    Dec 2005
    BFE, Tejas
    In a couple of months, ill sell ya my TF999 thats beefed up and just rebuilt
    lowballing someone
    Feb 2005
    Houstonish
    ive got a t400 froma waggy that you can have for cheap if yours craps out on you, came from a waggy....kinda our waggy
    Sep 2005
    1003 hardwood ln
    Quote Originally Posted by TexTJ209
    any idea what tcase was in that and which side drop it was?
    Sep 2004
    Waco, Tx
    Quote Originally Posted by colman
    That'd most likely be the AMC version of the TH400, with the output meant for a quadratrac. It'd be a little more difficult.
    Pretty sure all waggys of that era were the same side drop(driver's), and being a manual tranny that should have an NP208 I believe.
