Results 1 to 5 of 5
Thread: SplitFire Gauges???
    H-TOWN
    SplitFire Gauges???
    Anyone used or know much about splitfire gauges. I looked at them at thier booth at the Houston Dragstrip and they looked pretty good. They are almost half the cost of AutoMeter and do the same thing, plus much more versitile. The only problem is that I can't find a speedo
    Scott, FTAC '99
    '89 "CJ-7" - Her trail rig
    scott.schubring@williams.com
    Chubby Bunny davido's Avatar
    Mar 2002
    College Station, TX
    I know nothing about them, but I did stay at a Holiday Inn last night.
    j/k
    I just spent a bundle on AutoMeters, so I'm very interested....
    For Splitfires I looked here:
    http://www.247autoparts.com/store/electricmeters.html
    2 5/8" - Fuel Level $35.98
    and compared to UltraLite Autometers here:
    http://www.jegs.com/cgi-bin/ncommerc...65&prmenbr=361
    2 5/8" Electrical
    105-4414 Fuel Level, 0-90 Ohm, 1965-up GM $37.99
    105-4415 Fuel Level, 73-12 Ohm, Ford before 1987 and most Chrysler $37.99
    105-4416 Fuel Level, 240-33 Ohm, (2) $37.99
    105-4418 Fuel Level, 16-158 Ohm, 1987-up Ford $41.99
    Maybe I'm missing something. Where do you see them half price?
    If you're looking for good, cheap gauges, I'd just get these:
    http://www.jegs.com/cgi-bin/ncommerc...50&prmenbr=361
    ~dso
    H-TOWN
    mabey the sight that I was looking at yesterday was in pounds and not in dollers... I will look again later
    Scott, FTAC '99
    Mar 2002
    College Station, TX
    Also, here's a list of Summit Racing's gauges, I don't see them listed: http://store.summitracing.com/section.asp?d=10&s=118
    I thought Splitfire said that they carried them, but after reading again I see that it's only the plugs. http://www.splitfire.com/stores.htm
    Only two US companies carry the gauges. The only one online is:
    http://www.247autoparts.com/store/tachometers.html
    They ONLY sell Splitfires, not AutoMeters. Go figure.
    The best would be to find a site that sells both. That way you're dealing with the same markup scale. When I was shopping, I found that Jegs and Summit are within pennies of each other.
    ~dso
    H-TOWN
    Looks close to me be cheaper on others. The sight I looked at yesterday was in pounds, not dollars. They are just a little cheaper.
    Water temp - Auto Meter - Summit
    ATM-4337 2 1/16 in. diameter, 100 to 250 degrees F, electrical, Ultra-Lite series, water temperature gauge ... $38.95
    Water Temp - Splitfire - 247 Autoparts
    2 1/16" - Water Temperature (Electric)
    $37.98
    Tach - Auto Meter - Summit
    ATM-4497 3 3/8 in. diameter, 10,000 rpm, Ultra-Lite series, tachometer ... $88.95
    Tach - Splitfire - 247 Autoparts (not very comparable- different sizes)
    Tachometer 2 5/8"
    $56.98
    Oil Pressure - Auto Meter - Summit
    ATM-4327 2 1/16 in. diameter, 0 to 100 psi, electrical, Ultra-Lite series, oil pressure gauge ... $51.95
    Oil Pressure - SplitFire - 247 Autoparts
    2 1/16" - Oil Pressure (Electric)
    $41.98
    Includes 1/8" electric sender with 3/8" & 1/2" NPT adaptors
    Scott, FTAC '99
