i need some bushings to make an antiwrap bar, i have some 1 and 5/8th tube which is what i believe they fit into. Where is the cheapest place to get them. Fred? i need two for the axle side.
if you have access to a lathe you could get a dildo, stick it in the freezer, then turn the polyurethane down to whatever specs you need and bore it out
or call jc whitney and get a prothane kit
they fit 1.5" tube nice n tight. 1 5/8" will prolly be a slip fit.
yeah, I listed some part numbers there for people needing bushings.Originally Posted by agjohn02
m.o.r.e. also sells them individually w/ tabs
previous experence?Originally Posted by robertf03
Originally Posted by Reckless
just another unorthodox materials source
we used to make air filters at work using pipe screens. my boss told me he used to have to take the company credit card to the gas pipe every few months.
Hey Kevin, the cheapest place would be my house. I should have exactly what you need, new in the box...
yea, i guess i should build mine as well
1976 F-100 Kustom Krawler
1976 F-150 Custom
1964 CJ5
aight jordan ill give you a holler when i get out of class i need to borrow your battery charger again as well
