i know ive read about twin sticks popping out of gear before. mine doesnt do it. is it the front or rear that pops out of gear? reason i ask is because ed's detent springs are different lengths. this results in one being harder to shift than the other. this will also make it less likely to jump out of gear. ive got it set up with the stronger spring on the front shift rail as i seem to remember the front being the one that people have trouble with. if its both, ill shim the other spring too, but for now it makes the rear easy to shift. what say you?
edit: its a dana 300.
