i need some plate to make a winch mount for the front of the cj. it needs to be 30 x 8" and i need a hawse fairlead for the rear winch. i was thinking 3/8 for the plate unless someone knows of a better thickness
ill trade you a hawse for a roller
I would go with 3/16 or 1/4 plate you are not gonna be pulling out the Edmund Fitzgerald.Originally Posted by colman
Don't forget, he does drive a jeep.Originally Posted by fbronco86
i have pulled out a lot of full sizes witht the old winch and tore up that mount so i wasn't sure how big to make it this time don't want to have to do it again. and as far as the trade i need both a roller for the front which i already have and a hawse for the rear. if someone doesn't have one soon i will probably buy a new one
I have some 1/4". I need some 3/16"
Scott, FTAC '99
'89 "CJ-7" - Her trail rig
scott.schubring@williams.com
I may have a hawse I can sell you, i believe it is a superwinch
what do you want for it?
I have the warn winch plate I'll sell you, I won't need it anymore.
1988 Blazer...RIP
how much for the plate, wana trade for a warn reciever cradle that holds a winch?
well i got the warn mount plate from doug as well as a cv shaft so i can shorten it for the rear of the cj now all i need is a hawse fairlead and a warn quick connector for cheap
The warn quick connects are too expensive. Here is the part numbers for the ones yoou can get from Oreilly auto parts. I have got these for some of my customers before. You will need to check to see which ones they can get. You will need to order 2 of which everone you get.
part # line code
bh510 bwd for 6 gauge wire
bh518 bwd for 4 gauge
bh514 bwd for 1/0
bh516 bwd for 2/0
I saw some at the Clayton Napa/Feed store, they were grey but would have worked.
i have 4 welding lead connects but if someone had a quick connect laying around i would have used it i think that i will just solder the 2 sets of wire together instead
