anyone have a stock cj-7 pitman arm, and a 7/16"-1" reamer?????
i know where a few stock ones are in town
where? and about for how much, wait don't you have one from that waggy front end? will that fit?
it is longer but i think it will fit
well thats probably not a good idea then. where ar ethe ones in town that you know of?
hey garrett didn't you say you had the proper reamer for the dana 30?
I've got a reamer, probably should work depending on the taper you need
the kits at ok4wd says the reamer is 7/16" - 1". http://www.ok4wd.com/index.php/catal..._rod_flip_kit/
and i don't want to have to buy this for a one time use. unless maybe if no one has one to borrow, would andrew want to split the price of the reamer with me? you said you wanted to flip your tie rod and drag link too. The more people that want to do this the lower the price of the reamer. any takers?
maybe but i am putting a d44 from a waggy in with chevy knuckles so i might do the tie rods on the other side of the axle
the waggy arm is 3/4 of an inch longer, so not much. you can come over and check the size of the splines to see if they fit. you can have it for 10 bucks
what do you mean tie rod on the other side of the axle. you mean below the knuckle?
no behind it. as above the yoke
ive never seen that, are you working on the jeep tomorrow, if so need any help. i'm not doing anything and would help get the cj running if interested.
that sounds great, call me whenever you want to come over, i will hopefully be working by 9 am, i'm so close
does no one have a reamer with the right taper????? thats surprising
