put this in tech?
put this in tech?
is there any reason to go with a stainless exhaust over a aluminum one other then for esthetics? also is MBRP that much better then AFE exhaust system? the AFE one is cheaper for the same thing.
Steven W
02 Dodge 2500
Originally Posted by StevenAg03
All of the research I did on the ford showed that MBRP put together a better engineered and sturdier product. There is a few MBRP dealers in H-town also that will install it. With the aluminum, you will never have to worry about rust, with the stainless it is not so bad but you will eventually get some at the joints from the rubbing.
I have a 4" downpipe - and all the way out the back 4" too. Wolverton, you should come over, I can show you all the things that I did to my Dodge to make it better.
